marqs_ic
4 years agoClocked Video Input II vid_datavalid width is 1 regardless of pixels in parallel parameter
I'm feeding oversampled video into CVI II IP and trying to make it only read every Nth pixel. There seems to be vid_datavalid signal for exactly this purpose, but its width does not get expand...
- 4 years ago
Hi marqs_ic,
Good day.
Thank you for your input.
Will convey it to our internal team on this.
Do you still have further inquiries on this issue?
If there is no further question, I will transition this thread to community support.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
4 years agoHi marqs_ic,
Good day.
Thank you for your patience.
After further discussion with our internal team, I am afraid the CVI II does not support this usage model and as this is a non common use of it.
The method that you are trying to use the core in, is in a way that it does not support and at the moment, there is no plan to do so.
Thank you.
ZulsyafiqH_Intel
