Clocked Video Input II vid_datavalid width is 1 regardless of pixels in parallel parameter
- 4 years ago
Hi marqs_ic,
Good day.
Thank you for your input.
Will convey it to our internal team on this.
Do you still have further inquiries on this issue?
If there is no further question, I will transition this thread to community support.
Thank you.
ZulsyafiqH_Intel
Hi marqs_ic,
Good day.
Based on your reply, I believe that the vid_datavalid bit is deasserted due to not oversampling the input video.
According to the VIP Suite user guide, the CVI need to tie the signal high if you are not oversampling your input video.
CVI for Seperate Synchronization Format Video
Link: Video and Image Processing Suite User Guide - 3.1.3. Separate Synchronization Format
Would you mind sharing with me how you do that?
Any documentation/guide you are referring at?
Thank you.
ZulsyafiqH_Intel
