JLee25
Contributor
5 years agoClocked Video Input Clipping
I am using the CVI with 12G SDI for my system.
The device is C10GX220 and Quartus Pro 19.2.
The platform designer connection is,
CVI -> Stream Cleaner -> Scaler -> frame buffer -> CVO....
CheepinC_altera
5 years agoHi Johnson,
To further narrow down the issue, can you try to create simple design by replacing your CVI with TPG? Then run through Modelsim simulation to see the rest of the components are working as expected. This is to narrow down the location to CVI.
Another thing to try out is to port the example design to C10 device and test on your board with the same SDI input to see if there is any difference. If this is working, then you can further customize from here.
Chee Pin
