fxu001
6 years agoclick IP but can't launch the gui in Quartus 14.0
Hello, For some reason, some of existing IPs don't have "vho" files, so ModelSim gets fail for vcom-7. I want to click IP icon to regenerate vho file in Quartus 14.0, but click steps won't affect ...
KennyT_altera
6 years agoHi Fred,
Since you are using old version of Quartus. You can use native link to setup the simulation. https://www.youtube.com/watch?v=PmVVXQchv2c
From there, it will show you the correct steps and you can refer to the scripts that it used.
Also, you need to turn on the netlist generation in the megawizard as well.
I would suggest you upgrade to latest release of Quartus 18.1 if the device that you use permit.
- fxu0016 years ago
Hi KTan, Great. Now I have another issue: for some reason, when I launch the Tools -> Run Simulation Tool -> RTL simulation, Quartus II will re-generate "do" file that contains to read vho file. If I comment out vho file within do file, ModelSim can bypass that point. Now for some reason Quartus looks know I will overwrite do file; then, it will generate do file before I overwrite it. As a result, Now I can't bypass that point. My question: Do you know how to disable Quartus to generate do file in every times? Thanks -Fred - fxu0016 years ago
Hi KTan, I am fine now since I can launch do file using "do command.do" in the Transcript pane if there is a different time latency from Quartus II to generate update version. Basically I can manually update "do" file that I think it is okay version for me; then, I launch it again in Transcript pane. Although the steps are tedious, it is doable without block me:) Please keep this case until Wednesday. Thank you so much for you support! -Fred - fxu0016 years ago
Hi KTan, Can you generate file for cyclonev_phy_2ch_reconfig.vho? For some reason, I can generate phy RTL, but it did not include this file. Thanks, -Fred
