changing analog parameters using multiple reconfiguration profiles in arria10 native phy
As I understand it, you have some inquiries related to the PMA analog settings with multi reconfiguration profiles. Sorry as I am not very clear with your specific inquiry. Would you mind to further elaborate?
I notice that you have enabled the embedded reconfiguration streamer. When you reconfigure to a specific profile, all the parameters as shown in the Dynamic Reconfiguration tab -> Configuration Profiles -> IP Parameters will be applied. You can cross check if your targeted PMA analog configuration is captured correct or not by a specific profile by check in the profile comparison table under Configuration Profiles.
Please feel free to let me know if the above does not address your inquiries #1 and #2.
For inquiry #3, please help to further elaborate. Generally if you are writing directly to the register, it will overwrite the existing configuration.
