11 years agoCan't Simulate NCO IP core
Hello All. I've run into a problem simulating the altera NCO IP core in ModelSim Altera. I've created an instantiation with the correct parameters and Quartus can compile it fine (there are a f...
11 years agoVague recollection here ... but perhaps its for another IP core ... I'm pretty sure you need to simulate using the <pll_name>.vho file, rather than the <pll_name>.vhd file, which is for synthesis only.
Cheers, Dave
