rsing108
6 years agocan't program stratix 10 GX with pcie hard ip+ example design
I am getting the following errors while programming the Stratix 10 GX board with the PCIE hard ip+ example design.
quartus_pro 19.4
Error (18950): Device has stopped receiving configuration data ...
SengKok_L_Intel
6 years agoFrom the vendor.qsf file, the PCIe reference clock is using T34, but you are using AK41. Could you please double check? Or perhaps you can get a simple PCIe design from Bittware?
set_location_assignment PIN_T34 -to pcie_refclk
Regards -SK
rsing108
6 years agoHi @SengKok_L_Intel ,
I changed the refclk pin to the same as the vendor one and also changed the rest of the pins according the vendor's pin configuration. But there is still an error while programming the board:
Error(18952): Error status: Device does not accept configuration request
- rsing1086 years ago
Hi @SengKok_L_Intel ,It seems I need to get the server rebooted first. I will update you once I get it rebooted.
