rsing108
6 years agocan't program stratix 10 GX with pcie hard ip+ example design
I am getting the following errors while programming the Stratix 10 GX board with the PCIE hard ip+ example design.
quartus_pro 19.4
Error (18950): Device has stopped receiving configuration data ...
SengKok_L_Intel
6 years agoHi,
Are you using a custom board and this is not Intel FPGA development kit? I'm asking this is because, the device ID 1SG280LN2F43E2VG is not the same as Stratix 10 Development Kit at the link below:
Other questions:
- Does the server is power up, and there is a valid PCIe clock sending from the server to FPGA when you program the FPGA?
- Do you able to program a simple design (without the PCIe)?
Regards -SK
- rsing1086 years ago
Hi @SengKok_L_Intel ,
It's actually BittWare's 520n card:
https://www.bittware.com/fpga/520n/
There is a valid PCIE clock being sent to the FPGA and I am able to program a simpler design without PCIE ip
