rsing108
6 years agocan't program stratix 10 GX with pcie hard ip+ example design
I am getting the following errors while programming the Stratix 10 GX board with the PCIE hard ip+ example design.
quartus_pro 19.4
Error (18950): Device has stopped receiving configuration data ...
SengKok_L_Intel
6 years agoThanks for the reply.
Did you connect the PCIe End point to the root port with the proper PCIe reference clock before you program the SOF? If without a proper PCIe reference clock, you will fail the programming.
Regards -SK
- rsing1086 years ago
Hi @SengKok_L_Intel ,
I did not find any such step in the manual so I have not specifically defined it, but shouldn't it be already done while generating the example design? Also does this attachment help or should I provide any other file? Sorry, I am not much familiar with this IP.
