PDone
5 years agoCannot upgrade PLL IP
I am trying to run IP that I am using is upgraded.the IP Upgrade Tool. Most of the IP that I am using upgrades, but PLL Intel FPGA v!*.1 does not.
When I create an instance of the PLL using the Meg...
Ash_R_Altera
5 years agoRecommend you to follow the workaround mentioned in below link. It is known to work for v18.1.
Regards.
PDone
5 years agoTHX. I also have the same problem with the Altera Unique Chip ID. what file should I modify?
