ymiler's avatar
ymiler
5 years ago
Cannot open the project. Quartus Prime Settings file contains one or more errors
Hi
When I try to open <projet name>.qpf file - I got the mesage
"Cannot open the project. Quartus Prime Settings file contains one or more errors"
According to your recommendtion - (ID: 125080)
"Correct the QSF syntax errors described in the error messages, and then open the project"
But, I dont know what are the syntax errors - How can I know which lines/errors the Quartus found ?
Is there any log file ?
Yishay
  • Hi @ymiler
    Could you help to share the screenshot and a simplified design files with the error duplicable?
    I might need this information to file a request for the engineering team.
    Richard Tan
  • sstrell's avatar
    sstrell
    You could post the .qsf file here to let others help or just create a new Quartus project from scratch to create a new .qsf.
  • Hi
    This problem occur for time to time ,
    I prefer a log from quartus that indicate which & what is the sytanx error - If we dont have this option the other way is guess what is the problem
    Yishay
  • sstrell's avatar
    sstrell
    Just post the file here. I'm sure myself (or somebody) will be able to see the problem right away. If Quartus can't read the .qsf file and says just that, you're not going to get more detailed info.
  • Hi @ymiler
    You may need to share the design files so we can take a look for what goes wrong.
    Else, I recommend to create a new project per sstreell suggestion, and compare it with the one with error.
    Richard Tan
    • ymiler's avatar
      ymiler
      I found the problem in my QSF file by myself,
      But it's best parctice that Quartus will create log for easy inqiry
      Yishay
      • RichardT_altera's avatar
        RichardT_altera
        Hi @ymiler
        Good to know that you are able to found the solution.
        I will filed an enhancement request regarding this feedback such that the Quartus will report out a more useful message that show where goes wrong, instead of a generic messages.
        Richard Tan
  • It was simply syntax error -I had enviorment variable that I missed to define
    Yiahay
      RichardT_altera
      Could you help to share the line that you missed to define in .qsf? So I get a grasp of what it look like.
      Richard Tan
