SYadl2's avatar
SYadl2
6 years ago
Can we get generic matlab model where we can configure the architecture(variable streaming etc)
When we generate fft ip core, we are getting matlab model but we are able to see fixed architecture. can we get matlab model where we can change the architecture.
  • CheepinC_altera's avatar
    CheepinC_altera
    For your information, the Matlab model generated by the FFT IP core is the only available model available. Sorry for the inconvenice. As a workaround, you can configure the FFT IP in IP Parameter Editor and then generate the model. The Matlab model should have the same configuration as what you have configure. However, you might need to regenerate the model for different configuration.
    Chee Pin
    CheepinC_altera
    We shall continue to follow up on this through the IPS case. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
