SYadl2
6 years agoCan we get generic matlab model where we can configure the architecture(variable streaming etc)
When we generate fft ip core, we are getting matlab model but we are able to see fixed architecture. can we get matlab model where we can change the architecture.
CheepinC_altera
6 years agoHi,
For your information, the Matlab model generated by the FFT IP core is the only available model available. Sorry for the inconvenice. As a workaround, you can configure the FFT IP in IP Parameter Editor and then generate the model. The Matlab model should have the same configuration as what you have configure. However, you might need to regenerate the model for different configuration.
Chee Pin
