BKB
2 years agoCan we generate EMIF DDR4 without mem_alert_n or not connect the emif_alert_n in the instantiation
Hi Please refer the attached png/pdf of the pin map of two EMIF instantiations in our design. The initial board design shared a FPGA IO bank for some address/command signals of the two instances, r...
- 2 years agoThanks Adzim.
Best,
BB
AdzimZM_Altera
2 years agoHi BB,
You can share the RZQ pin with two RZQ ports but the VCCIO need to be the same.
If not, the calibration will fail.
For alert_n placement, there is not much restriction.
You may use your current plan to fix your problem.
Adzim
