BKB
2 years agoCan we generate EMIF DDR4 without mem_alert_n or not connect the emif_alert_n in the instantiation
Hi Please refer the attached png/pdf of the pin map of two EMIF instantiations in our design. The initial board design shared a FPGA IO bank for some address/command signals of the two instances, r...
- 2 years agoThanks Adzim.
Best,
BB
BKB
2 years agoHi Adzim,
I understand that there is current hardware to validate the placement of alert_n pin on recommended rzq pin and also for two RZQ ports driven by one pin. Hence i request you to please reach out to the EMIF IP design team and share their insights.
Best,
BB
BKB
I understand that there is NO current hardware to validate the placement of alert_n pin on recommended RZQ pin and also for two RZQ ports driven by one pin. Hence I request that you please reach out to the EMIF IP design team and share their insights.
Best,
BB
