1 Reply
- BoonT_Intel
Hi Sir,
I believe the DDR3L reference clock is set to SSTL135 IO standard? If yes, you may check is the 2.5V OSC able to meet the VIH/VIL requirement of the SSTL135 IO standard.
You may check the VIH/VIL requirement from C10 GX datasheet. Since it is clock, please refer to AC column.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-10/c10gx-51002.pdf#page=17
