calibration of ddr4 interface on 10AX066H4F34E3SG
Hi Andrey,
Thanks for sharing those files.
It's seems like the sdram_a[7...0] is the only group that failed in the calibration
Even after you swapping the group with sdram_a[15...8].
The sdram_a[15...8] group can do the calibration but not for the sdram_a[7...0].
There is one thing that I notice in the calibration report which is the VREFIN setting for the sdram_a[7...0] group is slightly lower than other.
Maybe you can take a look on the voltage for this group when running the calibration.
Also make sure that there is no connectivity problem on board.
You can try to set the Memory I/O Settings as below.
• Output drive strength setting = RZQ/7 (34 ohm)
• Dynamic ODT (Rtt_ WR) value = Dynamic ODT off.
• ODT Rtt nominal value = ODT Disable.
• Rtt Park = RZQ /3 (80 Ohm)
Adzim
Hi, Adzim
These settings didn't help
