Andrey_Fazan
5 years agocalibration of ddr4 interface on 10AX066H4F34E3SG
Hello! I'm trying to implement DDR4 40bit-wide interface with 3 devices MT40A512M16LY-062E. When I connect only one of 3 devices to the project, calibration and data exchange do well, but when I conn...
AdzimZM_Altera
5 years agoHi Andrey_Fazan,
Can you check the signal integrity of the board?
You can change the OCT value in the EMIF IP.
Can you also perform a simulation by changing the DQS group with other memory?
I mean here is like a memory A is connects to the Group 0 and 1.
Then connects it to the Group 2 and 3.
Adzim
