Andrey_Fazan
5 years agocalibration of ddr4 interface on 10AX066H4F34E3SG
Hello! I'm trying to implement DDR4 40bit-wide interface with 3 devices MT40A512M16LY-062E. When I connect only one of 3 devices to the project, calibration and data exchange do well, but when I conn...
AdzimZM_Altera
5 years agoHi Andrey_Fazan,
Thanks for sharing the EMIF IP configuration.
When I looked at your configurations, I can see that the ECC is not enable.
If I'm not mistaken, the 40bit = 32bit +8bit ECC.
Why not you disable the x8 SDRAM component and use both x16 SDRAM components to make a 32bit-wide interface?
Adzim
