Andrey_Fazan
5 years agocalibration of ddr4 interface on 10AX066H4F34E3SG
Hello! I'm trying to implement DDR4 40bit-wide interface with 3 devices MT40A512M16LY-062E. When I connect only one of 3 devices to the project, calibration and data exchange do well, but when I conn...
Andrey_Fazan
5 years agoHi, Adzim!
If that thus matter if you change the group for your device? - It is impossible to change group for devices because only 8 DQ pins from device "Bank C" are connected to the FPGA
Can check that the reset signal is not triggered during the calibration process? - Reset signal is not triggered
I attach also configuration list for EMIF example, hope, it can help to solve the problem
Thank you!
