calibration of ddr4 interface on 10AX066H4F34E3SG
Hi Andrey_Fazan,
Thanks for sharing the report.
Are you also able to attached the calibration report for the one device testing?
From the report, it's can be seen that the calibration is stopped at DQS2.
Can you identify which device that has been used for that group?
Can you check the connection on that device?
Can you confirm that all connections on your design are connected correctly?
Or if possible, can you test it on different board?
Adzim
- Andrey_Fazan5 years ago
Hi, Adzim!
I attach reports for each memory deviceFrom these reports, you can see, that every separate device calibrates correctly, so, I suppose, there are connected correctly too.
In archive:
- bank C - the first device (DQS0)
- bank B - the second device (DQS1, DQS2)
- bank A - the third device (DQS3, DQS4)
Such names for devices are just used in our project
