BUG - Fir filter coefficient read mode
Hi Chee Pin!
As I written in my previous post, the simulation does not work and does not behave as the real implementation -> therefore I started to capture data with the Signal Tap Logic Analyzer!
So setting up a simulation does not help. As I already wrote in an other post of a different topic.
Intel decided to stop the support requests and there is no NDA so I can not give company implementations to the puplic! So I cannot give you my project.
You could setup a project and capture real data with Signal Tap Logic Analyzer to see the issue. Same is true for simulation.
I will not setup Quartus 18.1 because as far as I saw there were no important changes. And if I have a look to the FIR filter release notes there were no changes after 17.1:
https://www.intel.com/content/www/us/en/programmable/documentation/hco1421697814795.html
Erich
