BQi
6 years agoAvalon to AXI bridge
I did know that Qsys can translate avalon to axi or axi to avalon transparently. but can we get the translation bridge text code? We would use them outside qsys. thanks
KennyT_altera
6 years agoIf you connect it in the qsys, you will find the name for it.
In the system -> show system with platform designer interconnect, it will show all the translator or extra interconnect over there.
However, for pro edition:
Translator is meant to be used inside the interconnect with transform. Its parameterization depends on overall system configuration and can be correctly done by the transform. Hence the transform was removed from IP catalog. It still gets generated as part of interconnect.
It would be engineering decision to remove it. If you would like to look into the real design, you will have to look into the standard edition.
