BQi
6 years agoAvalon to AXI bridge
I did know that Qsys can translate avalon to axi or axi to avalon transparently. but can we get the translation bridge text code? We would use them outside qsys. thanks
KennyT_altera
6 years agoAny reason that you want to do it outside qsys? We don't recommend user do that as the translator added by the qsys automatically. Doing it outside the qsys might hit a lot of problem, your functionality might broke down if you did not test it correctly in the simulation.
You can look into what interconnect had been added in the qsys.
- BQi6 years ago
I need Avalon to AXI cross-clock domain bus transform component But I can not find it in platform designer. Only have single clock domain component. Do you have the idea?
