15 years agoAvalon-ST Multiplexer
Hello, I am trying to do a multiconnection system to the TSE core. Hardware generated stream would go directly to the TSE and the other packets (ARP/ICMP/etc) should also go from the sgdma to TSE....
9 years agoHi, Socrates, did you find anything else squirrely with channels? I am trying to use an input of a 20-bit channel on an 8-port mux. Should be 23 bits total (Altera allows 0-31), but Quartus keeps saying it's out of range and keeps asking for 0-8 channel bits, when the Embedded IP User's guide says it should support up to 31 total.
