s002wjhwen
2 months agoavalon MM generator read issue
I'm using avalon MM BFM to stimuli my slave avalon interface, however, when doing u_avalon_MM_gen.mm_master_bfm_0.set_command_address(addr); u_avalon_MM_gen.mm_master_bfm_0.set_command_byte_enable...
s002wjhwen
2 months agoi just used completed_read_response.data instead, return_response.data has 3ns, delay, if i pop it, it only get the data from previous push which is 0. so delay dont work
ShengN_altera
2 months agoUnderstood that. The completed_read_response.data should be enough already
