s002wjhwen
2 months agoavalon MM generator read issue
I'm using avalon MM BFM to stimuli my slave avalon interface, however, when doing u_avalon_MM_gen.mm_master_bfm_0.set_command_address(addr); u_avalon_MM_gen.mm_master_bfm_0.set_command_byte_enable...
s002wjhwen
2 months agoso i found the issue.
data = u_avalon_MM_gen.mm_master_bfm_0.completed_read_response.data[0];
data2 = u_avalon_MM_gen.mm_master_bfm_0.return_response.data[0];
$display("Data=%0h Data2=%0h", data, data2);
data will show the correct 1020001 , but return_response.data is 0 seem like there are some delay between these two. i'm using quartus 23.4 to generate IP for avalon MM BFM.
ShengN_altera
2 months agoPut a delay before data2?
