17 years agoavalon mm byte enable
In the project we are currently working on, we want to read and write pixels to external DDR SDRAM. We need to be able to use byte-mask / byte-enable bits to not overwrite some previously writt...
14 years agoThank you, this is the solution I've already found. Now in have a frame reader and it wrote a writer component too with same data format. I looked at your sgdma too ..impressive work!
