17 years agoavalon mm byte enable
In the project we are currently working on, we want to read and write pixels to external DDR SDRAM. We need to be able to use byte-mask / byte-enable bits to not overwrite some previously writt...
14 years ago --- Quote Start --- You set the byte enables on the master side, I haven't used that bridge before but it should be possible to do 8, 16, and 32 bit (aligned) accesses. You don't have to use 8 or 16 bit accesses for the narrow slave, if you perform a 32-bit access the interconnect will chop that up into two sequential 16-bit accesses for you. If you created the component with the slave port and have not included byte enables I highly recommend doing so, I have seen lots of people shoot themselves in the foot by not including byte enables on their IP. --- Quote End --- I added a byteenable (2 bits) on the slave side. Does this mean the only valid master addresses are: 0x00 0x04 0x08 0x0C ... and son on. ( I can no longer use address 0x02, 0x06, 0x0A..)? Also I have no clue as to how set the byteenable on master side as 0011..if you have any idea, please help me out. Thanks.
