17 years agoavalon mm byte enable
In the project we are currently working on, we want to read and write pixels to external DDR SDRAM. We need to be able to use byte-mask / byte-enable bits to not overwrite some previously writt...
16 years agoThe restriction has to do with masters and slaves of different widths. If you have problems implementing the logic to break down the byte enables into supported combinations let me know and I can email you what I'm using.
