CBOLL2
6 years agoAvalon Master/ Slave Template Third Party Questasim Simulation
Hi, I have created a project with platform designer, making use of the avalon memory mapped master and slave template IP: https://www.intel.com/content/www/us/en/programmable/support/support-resour...
KennyT_altera
6 years agoMy suggestion is you try on Modelsim_ase version for the simulation first to narrow down whether it is tools issue.
Usually, this would not be a problem as this is a common IP.
https://www.intel.com/content/www/us/en/programmable/documentation/gft1513990268888.html
Questasim support should be 10.6d for Quartus 19.3
Similar to modelsim, Questasim should be 10.5b for Q17.1std version
Can you use the latest release of Quartus instead? It is Q19.1 for std version linux. 18.1 for std version windows.
CBOLL2
6 years agoThank you for your reply.
I changed to modelsim and tried the versions I had available and is now working.:
Quartus 17.1 standard
Modelsim 10.0e
Many thanks
