13 years agoAvalon- Wishbone Wrapper OpenCores CAN Protocoll Controller
Hi, I know that this has been discussed in some old threats but I could not get some real help from those. I want to use the CAN Protocoll Controller in my NIOSII system designed with QSYS. I t...
10 years agoI don't have the time to carefully analyze your code now.
Just a few question which could help to identify your problem: - do you connect to a CAN device on the other side or do you test the core without bus connection? - are timing registers correctly configured for the bus baudrate? IIRC 25MHz clock frequency is generally not used for CAN since you can't achieve all standard baudrates; if you can have it, use 24MHZ or 48MHz. - Do you see any waveform on bus lines when you call the send_msg the first time?
