14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years agoThiago,
Could you run the Open IP Core ? When i try to compile the ASI MegaCore i got the following error: Error (20005): A license file is required to enable compilation of your design for the Cyclone family of devices It was waited :-) I could not identify in altera documentation how to run the open core ASI. Somebody had success in this mission ? Somebody can indicate a documentation that could help me to compile and simulate Open Core ASI in Quartus II 11.0 web edition. Thanks, Best regards
