14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years ago --- Quote Start --- So there is none ready to use? I still have to code some parts of it? Regards, --- Quote End --- The Altera ASI core is ready to use. What do You mean by configuring transport stream? What do You need to configure there? ASI core takes clock and data (start is not required). Just connect the signals and it does its job.
