14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years ago --- Quote Start --- Hi Thiago, If you know what you have to do to reformat the data, then it would be easy to write your own. You could always create a simulation with the Altera ASI IP code, and look at what the output data stream looks like for your given input data, and then write a core to reproduce that functionality. Cheers, Dave --- Quote End --- So there is none ready to use? I still have to code some parts of it? Regards,
