14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years agoHi Dave, the SPI output from the demodulator has the attached waveform.
It is simple: 8 bits data, CLK, sync byte, valid byte. The CLK frequency is around 5 MHz. TTL levels. And the DVB-ASI output is based on a standard I guess, not much to work on here. Socrates, which ASI IP are you reffering to? The one available at Altera? It would be better if it was free :-P Is it easy to configure the Transport Stream input? Regards, Thiago
