14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years ago --- Quote Start --- Actually, what I need is to convert the parallel transport stream coming out of a digital tv demodulator into ASI. It should be very simple, 1 parallel In 1 ASI --- Quote End --- That is still not much information. I'm looking for things like; * I need to take a 3.3V single-ended 16-bit parallel data stream at XXX MHz * 8/10B encoded into YYY format packets, and * transmit at a serial data rate of ZZZ using 75-ohm transmission line drivers Then you can get feedback on which FPGA is appropriate. Cheers, Dave
