14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years agoHello,
Sorry for the lack of info. Actually, what I need is to convert the parallel transport stream coming out of a digital tv demodulator into ASI. It should be very simple, 1 parallel In 1 ASI Out, maybe it is possible to use a very cheap FPGA. The ASI IP that I´ve seen only works with video conversion, or IP (Internet Protocol) bridge. I was trying to accomplish that using HOTLink from Cypress, but the FPGA is the correct way to make it work. Regards, Thiago
