14 years agoASI output IP - Easy to use?
Hi, I am new to Altera solutions, but I was looking for an "easy way" to convert parallel TTL (even LVDS) to ASI Out. I found the ASI IP but I am not sure how easy it is to integrate, I mean, if it i...
14 years agoBy ASI-out, you mean this video interface?
http://www.tvtechnology.com/article/12126 What IP are you referring to? I see you have not posted enough yet to be able to include links, but you could provide a little more information on the source of the IP. Do you have a board that has an ASI-Out interface? The article comments that it use 75-ohm transmission lines and is similar to SDI. The Stratix IV GX board has an SDI interface that uses external drivers interfaced to transceiver channels. Do you have something similar? Cheers. Dave
