RLi1
6 years agoarria10 PCIE IP Example design simulation error
Generate Example design with Arria 10 PCIE IP, modelsim simulation of the generated Example design, according to the steps: do msim_setup.tcl->ld_debug, ld_debug when the following error occurs: Vlo...
SengKok_L_Intel
6 years agoIt will be good if you can let us know if you are running at Gen2 or Gen 3? Besides, did you follow the above example design to run the simulation?
Regards -SK
