RLi1
6 years agoarria10 PCIE IP Example design simulation error
Generate Example design with Arria 10 PCIE IP, modelsim simulation of the generated Example design, according to the steps: do msim_setup.tcl->ld_debug, ld_debug when the following error occurs: Vlo...
SengKok_L_Intel
6 years agoHi,
What is your PCIe IP setting (e.g. Gen2 or Gen3)?
Did you refer to the following link to generate the example design, and then go to the right directory to run the simulation?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-a10-pcie-avst.pdf
Regards -SK
