11 years agoArria V Starter Kit: SDI re-transmitter
Hi, Using Arria V Starter Kit I'm trying following: Apply HD video to SDI input; Inside the FPGA: Receive HD video using standard SDI 14.0 IP module in RX mode; Inside the FPGA...
11 years agoOk.
I have found the solution by myself. I provide it here, may be it will be useful for somebody. The SDI TX reference clock input has to be connected to SDI RX restored clock output through a standard Atera's PLL in direct mode w/o frequency conversion . Altera claims that from jitter minimization point of view it is not the best solution (Table2-1, https://www.altera.com/en_us/pdfs/literature/hb/arria-v/av_53001.pdf). However both SDI analyzers show proper eye opening with relatively low jitter about 0.1 UI. Regards.
