14 years agoArria II GX Devkit TSE RGMII Help
Hi all, I've been struggling to get the ethernet port working on the Arria II devkit (after getting flash, DDR2, and DDR3 working). I am mimicking the code found in bts_config, but using vhdl,...
14 years agoIf it's Marvell 88E1111, then check the datasheet. You need to keep it in reset for some time. I've made 16bit counter that runs out in about 0.5sec and then releases the reset.
You can check if this is the same issue: wire phy reset signal to the button, which resets all the system. Run the system, push reset button and upload Nios once more. Now ethernet should work.
