14 years agoArria II GX Devkit TSE RGMII Help
Hi all, I've been struggling to get the ethernet port working on the Arria II devkit (after getting flash, DDR2, and DDR3 working). I am mimicking the code found in bts_config, but using vhdl,...
14 years ago --- Quote Start --- The example project should run fine. I use RGMII bus on my Cyclone III board and it works fine either 10/100 or 1000Mbps. --- Quote End --- That's good to hear. That means I must have done something wrong in the FPGA code. I guess it is time to break out signaltap. Thanks
