SKara
7 years agoArria 10/Cyclone 10 Transceiver
I am using the "Transceiver Native PHY Intel Arria 10/Cyclone 10 FPGA IP" and set "adaptation enabled" in the DFE mode.
In this mode, will the DFE tap be always calibrated automatically or do we need to write some registers to initialize the calibration each time?
If we need to write to some register, could you please send us a reference?
1 Reply
- Deshi_Intel
Hi Serge, User needs to trigger the DFE adaptation via some register write. You can refer to Arria 10 transceiver phy user guide doc page (464/465) for the instruction on how to do it. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf Thanks. Regards, dlim
