Basti3n
5 years agoARRIA 10 temperature sensor: 25 Celsius degree offset
We have some issue at work with a couple of ARRIA 10 FPGA temperature sensors reporting the wrong temperature value. It seems to always have an offset of around 25 degrees, compared to another on-boa...
Ash_R_Altera
5 years agoHi,
I am not sure which Quartus version is being used. As per below KDB link, there was an issue in Quartus Prime Pro 20.1.
If you are using the same version please update the software.
Basti3n
5 years agoHi,
Thank you for your reply. Actually this is an old image built with Quartus Prime Pro 17.1.1. The same build is used on all the cards.
