Mathis1
1 year agoArria 10 PLL Reference clock sources
Hello, quick question: Can the HPS user clock be used as the reference clock to an IOPLL IP on the Arria 10? If yes, are there some cases where the IOPLL output clocks would be unsuitable bec...
tehjingy_Altera
1 year agoHi
Yes, you can use the User Clock from the Arria10 HPS to be connected to the IOPLL IP.
Are you facing any problem with this connection?
Jingyang, Teh
