lcy2000
1 year agoArria 10 PCIe Gen 3 stuck at Equalization.Phase3
Hi, I'm writing a design with Arria 10 AVST PCIe IP (Quartus 24.3). Currently we have encountered equalization problem at PCIe Gen3. We are using A10GX1150 DevKit as an add-in card attached to a...
- 1 year ago
Hi ChenYang,
In my understanding of PCIe, contrary to MalfTLP, BadTLP is a much more underlayered concept with a only a few reasons to trigger: (1) Link CRC error (2) Sequence Number error. (Refer to PCIe 3.0 Spec, Figure 3-17, Page 185/860)
>> Okay
>> Another that that you could check will be- Do you check if your endpoint has received the 8 required consecutive TS2's ?
- But before it is able to complete sending 16 TS2s, the downstream port sends EIEOS and then starts sending TS1 ?
- Based on my experience, once it meet sending 16 TS2, it shall transition to Recovery.idle since the requirement for that transition are meet >>Recovery.equilization phase X >> L0.
Wincent_Altera
Wincent_Altera
1 year agoHi,
I wish to follow up with you about this Forum case. Do you have any further questions on this matter ?
Else do I have your permission to close this forum ?
Wei Chuan
