fst21
4 years agoArria 10 Low Latency 40G Ethernet IP with Quartus 21.3
Dear Community,
When upgrading from to the new Quartus version 21.3, the following errors occur in the IP Core Low Latency 40G Ethernet IP for Arria 10:
Error(13223): Verilog HDL or VHDL error: No ke...
Deshi_Intel
4 years agoHi,
I used Quartus Linux v21.3 to generate and compiled Arria 10 Low Latency 40G Ethernet IP example design and it works fine.
Therefore, I suspect your issue could be due to your licensing issue.
- Can you share your licensing *.dat file for debug review ?
- Also just to confirm are you using exactly same 40G IP setting between old Quartus version vs this latest Quartus v21.3 ? For instance, did you enable KR-PHY feature as I recall KR-PHY feature may require separate license to use it
dlim
