Arria 10 GX - RSU (Remote System Update) over PCIe - "Memory at <unassigned>" issue
At which stage from the design example did the problem occur? Is it during PCIe setup on linux, etc..
Aiman
As mentioned in the first message, we had the Arria 10 GX FPGA development board inserted in the PCIe slot of the motherboard of the host PC with the above mentioned design on the FPGA
When we ran `lspci -v` in a terminal on the host pc(running Ubuntu 20.04.2 64 bit OS), we got the below,
01:00.0 Unassigned class [ff00]: Altera Corporation Device e001 (rev a5)
Subsystem: Device a106:2484
Flags: fast devsel, IRQ 11
Memory at <unassigned> (64-bit, prefetchable) [disabled]
Capabilities: [50] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [200] Vendor Specific Information: ID=1172 Rev=0 Len=044 <?>
Capabilities: [300] Secondary PCI Express
Capabilities: [800] Advanced Error Reporting
Kernel modules: altera_cvp
As seen in the `lspci -v` output above, we are getting Memory at <unassigned> (64-bit, prefetchable) [disabled]
Sachin
- sachin_blr5 years ago
We are still facing the above mentioned issue. Would it please be possible to provide any input(s) to address the above mentioned issue ?
Thank you,
Sachin
